MAF choice for forced induction.
Old Feb 13, 2005 | 06:31 PM
2001WS6Vert's Avatar
Default MAF choice for forced induction.
I have the stock screened MAF on the inlet side of the blower. I've read that I might pick up a lb. of boost if I switch to the pressure side. I was thinking I should go with an 85mm MAF, but which one? Screened or descreened? I run a FMIC now so if you see the picture link it shows a more or less stock looking Vortech system. Here is a picture of the current setup. I am going to put the MAF as close to the throttle body as possible.
Old Feb 13, 2005 | 07:02 PM
Another_User's Avatar
If you want to run a MAF, you should get the biggest unscreened MAF you can get. Just make sure you can tune for it and you should be fine.
