Getting code p1626.....
Old Feb 15, 2005 | 03:32 PM
Dano 00TA's Avatar
Default Getting code p1626.....
My 00 Silverado 5.3 has the security light periodically come on and when I pulled a code it gave p1626 which I did search for and found it's:
P1626 - Theft Deterrent Fuel Enable Signal Not Received
but what causes this, and is there anything I can do to fix it other than take it i=to a dealer
Thanks
Old Feb 15, 2005 | 03:36 PM
horist's Avatar
https://ls1tech.com/forums/search.php?searchid=1259157
Others have had this, seems the problem is generally:
1. The chip (resistor) in the key is messed up (if it's PASS KEY 2) ... try a spare key
2. The Gauge Cluster fuse is blown
There are some other posts about it in the above link
Old Feb 15, 2005 | 07:44 PM
Dano 00TA's Avatar
Thanks Horist, It's a Pass Lock system since there is no visible resister in the key itself. Guess That kinda kills the easy "try a new key" cure now I figured it's gonna be something expensive as it usually is when I have a problem.
Old Sep 12, 2005 | 09:52 AM
SURPRYZ's Avatar
Thankyou for that help about gauge fuse
p.s. Search option on this site rules!
