Iam getting a heater code of 1133 Why?
Old Mar 13, 2005 | 03:30 PM
rawlitogut's Avatar
Default Iam getting a heater code of 1133 Why?
Its saying inceffent heater,what can cause this? A leak,cloged muffler.
Old Mar 13, 2005 | 07:34 PM
slow's Avatar
longtube headers?
Ryan
Old Mar 15, 2005 | 12:43 AM
Green Thunder's Avatar
DTC P1133 or P1153
Circuit Description
The powertrain control module (PCM) monitors the heated oxygen sensor (HO2S) activity for 100 seconds. During this period, the PCM counts the number of times that the HO2S switches form rich to lean, and from lean to rich. A DTC P1133 or a DTC P1153 sets when the PCM determines that the HO2S did not switch enough times.
A lean-to-rich switch is determined when the HO2S voltage changes from less than 300 mV to more than 600 mV. A rich-to-lean switch is determined when the HO2S voltage changes from more than 600 mV to less than 300 mV. This diagnostic runs once per ignition cycle.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0117, P0118, P121, P0122, P0123, P0200, P0300, P0410, P0440, P0442, P0446, P0452, P0453, P1258, P1415, P1416, or P1441 are not set.
The loop status is Closed.
The engine run time is more than 160 seconds.
The engine speed is between 1,000-2,300 RPM.
The ignition 1 signal is between 9-18 volts.
The engine coolant temperature (ECT) is more than 50°C (122°F).
The evaporative emissions (EVAP) purge solenoid is more than 0 percent.
The mass air flow (MAF) is between 20-50 g/s.
The throttle position (TP) is more than 5 percent.
The fuel tank level remaining is more than 10 percent.
Conditions for Setting the DTC
The HO2S lean to rich and rich to lean switches are less than a calibrated amount.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step determines if the condition is present. This test may take 5 minutes for the diagnostic to run.
When DTCs 1133 and P1153 are set at the same time, a fuel contamination condition is probably present.
An exhaust leak 6-12 inches from the HO2S can cause a DTC to set.
This step tests whether a good ground circuit is available.
This step tests the integrity of the HO2S high signal circuit to the PCM.
Certain RTV silicone gasket materials release vapors that can contaminate the HO2S. Silicone in the fuel can also cause silicone contamination. If the sensors appear to be silicone-contaminated, and if all the silicone sealant is a non-silicone base, advise the customer to try a different fuel company. A missing fuel filler restrictor indicates that the customer may have used leaded fuel.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Important
If any DTCs are set except DTC P1133 or P1153, refer to those DTCs before proceeding with this diagnostic table.
Install a scan tool.
Idle the engine at the normal operating temperature.
Operate the vehicle within the parameters specified under Conditions for Running the DTC in the supporting text.
Observe the diagnostic trouble code (DTC) Information with a scan tool.
Did DTC P1133 or P1153 fail this ignition?
Go to Step 3
Go to Intermittent Conditions
3
Did both DTC P1133 and P1153 fail this ignition?
Go to Step 8
Go to Step 4
4
Inspect for an exhaust system leak. Refer to Exhaust Leakage in Engine Exhaust.
If you find an exhaust leak, repair the exhaust leak as necessary.
Did you find and correct the condition?
Go to Step 14
Go to Step 5
5
Inspect for the following conditions:
Ensure that the HO2S is securely installed.
Inspect for corrosion on the terminals.
Test the terminal tension at the HO2S and at the PCM.
Inspect for damaged wiring.
Did you find and correct any conditions?
Go to Step 14
Go to Step 6
6
Disconnect the HO2S.
Jumper the HO2S low signal circuit on the PCM side to a known good ground.
Observe the HO2S voltage on the scan tool.
Does the scan tool indicate a voltage that is within the specified range?
350-550 mV
Go to Step 7
Go to Step 10
7
Jumper the HO2S high and low signal circuits on the PCM side to a battery ground.
Observe the HO2S voltage with a scan tool.
Does the scan tool indicate a voltage that is below the specified value?
200 mV
Go to Step 13
Go to Step 9
8
Important
Determine and correct the cause of the contamination before replacing a sensor. Inspect for the following conditions:
Fuel contamination
Use of an improper RTV sealant
Engine oil or coolant consumption
Replace the affected heated oxygen sensor. Refer to Heated Oxygen Sensor (HO2S) Replacement Bank 1 Sensor 1 and/or Heated Oxygen Sensor (HO2S) Replacement Bank 2 Sensor 1 .
Did you complete the replacement?
Go to Step 14
9
Remove the jumper wire from the HO2S low signal circuit.
Measure the voltage from the HO2S low signal circuit to a battery ground using the DMM. Refer to Measuring Voltage in Wiring Systems.
Does the DMM indicate a voltage near the specified value?
5 V
Go to Step 12
Go to Step 11
10
Repair the HO2S high signal circuit for a short to ground or shorted to a voltage. Refer to Heated Oxygen Sensor (HO2S) Wiring Repairs in Wiring Systems.
Go to Step 14
11
Repair the open in the HO2S low signal circuit, or repair the poor PCM connections. Refer to Heated Oxygen Sensor (HO2S) Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
12
Repair the HO2S high signal circuit for an open or repair the poor PCM connections. Refer to Heated Oxygen Sensor (HO2S) Wiring Repairs in Wiring Systems.
Go to Step 14
13
Replace the affected HO2S. Refer to Heated Oxygen Sensor (HO2S) Replacement Bank 1 Sensor 1 and/or Heated Oxygen Sensor (HO2S) Replacement Bank 2 Sensor 1 .
Go to Step 14
14
Use a scan tool in order to clear the DTCs.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 15
Go to Step 2
15
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Old Mar 15, 2005 | 02:21 AM
rawlitogut's Avatar
Thankyou for the info,where did you find this? I think my problem is my leak.
Old Mar 15, 2005 | 09:18 AM
Lets just say I cant share where I got it.. If you need any more diagnostic info dont hesitate to PM me..
Old Mar 17, 2005 | 07:04 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Great info!!!!!!!!!!!!
Flipper you da man! These little headaches cause so much lost sleep and frustration. You have no idea how nice it is to have this type of info provided.
Now that my friend is what I call information sharing!!!
Old Mar 18, 2005 | 12:50 AM
God Forgives I Dont's Avatar
Dude that was great helping him out like that! I could have used some info along those lines when I was having problems with the TPS / MAP because of the big cam. I got it figured out anyway, just wanted to give you a for providing such kick *** info on that problem.
Old Mar 18, 2005 | 01:20 AM
Feel free to PM me if you need any help on anything!
