Pcm Problem
I connected a 560 ohm resistor to it from ground and the pin went to zero volts, the pin acts like an input- it won't supply any current. I double checked all power and ground connections, the PCM ignition feed and the fuel pump control connection. Even if the PCM were fried the 12 volts on the pump control pin should have supplied enough current to operate the pump relay. Don't have a scanner yet so I can't tell the condition of the PCM.
The PCM came from a wrecked 98 Camaro so it must have been working when it wrecked!!
Anyone have any idea what the problem might be??
BTW, anyone figured out how to remove the PCM pc boards from the aluminum housing base. I may have to put the thing on a bench and troubleshoot it. The are some little white tabs that look like they may release the boards but havn't figured them out yet.
