HP Tuner Question
Old Mar 14, 2005 | 10:05 AM
hc_performance's Avatar
Default HP Tuner Question
Right now I am at 10.9-1 A/F at WOT and no matter what changes I make to my pe table it doesn't seem to change my A/F ratio. Here is what my pe table is at right now and as you can see in the higher rpms I should be mathmatically in the 14-15.0 : 1 a/f range. It almost seems like it maybe looking at another table. Has any one else had this problem? What do you guys think? Btw this is an n/a A4 car.
1.225 1.225 1.225 1.228 1.228 1.228 1.228 1.228 1.228 1.063 1.063 1.063 1.063 0.965 0.98 0.98 0.98 0.98 0.98
Old Mar 14, 2005 | 10:16 AM
Black02SS's Avatar
Post up your Open Loop F/A Multiplier Table
Old Mar 14, 2005 | 10:28 AM
jimmyblue's Avatar
Moderator
Be sure you have the cat overtemp (COT) turned off if
you have no cats, or try to push it down some if you have
the cats still in place (bearing in mind you will burn them
if you run too hot, too long).
Old Mar 14, 2005 | 11:12 AM
Black02ss I am not sure how to post pictures of my tables. If you could tell me how I would be happy to.
Jimmyblue my cot was not disabled. I don't have cats so I will disable it and try it on my lunch break.
Thanks for the help guys!!!
Old Mar 14, 2005 | 07:57 PM
Jimmyblue, your a genius. That fixed it. 13.0-13.3 across the board now. Thanks!!!
