What all is needed to hook LM-1 to HPTuners?
the base LM-1 unit will come with:
1 Analog out cable (for 2 outputs)
1 Serial cable (for programming the LM-1, you just need to set it to output 0 volts for 10:1 and 5 volts for 20:1)
1 LSU4+ Wideband O2 sensor
1 wire to go from O2 sensor inside car
1 wire to power the LM-1
and the LM-1 unit itself
as for install...
1. Configure the LM-1 to output 0-5 volts as mentioned above
2. Connect output wire to one of HPTs input wires
3. Connected HPT ground to LM-1 ground (part of analog out cable)
4. Add Wideband to your Chart (instructions in HP Tuners)
and that's pretty much it... the LM-1 comes with instructions on how to calibrate (you calibrate the sensor in free air prior to install)
Remember though... if you are going to levae the sensor in all the time, you must power it whenever the car is running (turn LM1 box on) ... otherwise you'll be buying new sensors quite often (fortuanetly they're only about 40 bux shipped)
as for install...
Restricted User
I have had my LM-1 since the initial GP on here over a year ago, never got an Analog output cable, so I will order that now. Got everything else, well maybe not the book from it, but will looksee on here & HPT's site to get the wiring hookup. Thanks again Mike.
