reasons to not go into pe
Old Apr 1, 2005 | 11:02 PM
Stroker 1500's Avatar
Default reasons to not go into pe
Ok im trying to figure out why im running lean. im starting to belive its not going into PE. Now im wondering what are some things that will cause it not to go into PE. Also is 15 a PE cell i hear that it is just a heavy load cell but not necisarely PE.. here is where im at if anybody wants to read http://www.monodax.com/forums/showth...6&page=1&pp=10
Old Apr 4, 2005 | 04:20 AM
i guess its either a stupid question or no one knows....
hurray for another un answered thread
Old Apr 4, 2005 | 08:40 AM
Black02SS's Avatar
Do you have COT enabled or disabled? What program are you using to do your tune? If it is HPT, can you post it up?
Old Apr 4, 2005 | 04:32 PM
COT was originally enabled and i thought it may be part of my problem so i dissabled it and it had no affect on my a/f. Im using tunercat to tune.
Old Apr 4, 2005 | 05:18 PM
white2001s10's Avatar
You're not running through catalytic converters are you?
Old Apr 4, 2005 | 05:41 PM
the cats are still on. i only dissabled cot brifley to see if maybe that was contributing to my problem
Old Apr 4, 2005 | 10:39 PM
SmokingWS6's Avatar
Log commanded AFR and see if its dropping from 14.7 to whatever at WOT.
Old Apr 5, 2005 | 04:24 AM
my buddy who was watching the tech 2 a couple months ago (was still having the same problem then) said that the a/f on the screen was 13.0 which would be the commanded. I tried logging what it was commanding again tonight to see but im using autotap and for some reason when i did a software upgrade it won't let me use that parameter anymore
Old Apr 5, 2005 | 09:15 AM
jimmyblue's Avatar
Moderator
You should be able to log the fuel air multiplier
since that's more of a "native" param, used
directly. 1.000 will be your closed loop target,
1.250 is stock PE table value (11.7:1 commanded
AFR), 1.13 is stock Open Loop Fuel Air table which
would be PE disabled, open loop, high MAP (about
13.0:1 target). If you catch the fuel air multiplier
PID and back-reference the tables you can deduce
what mode it's been in.
Old Apr 5, 2005 | 11:54 PM
ok, i made another log tonight and i found that for some reason autotap doesn't like me and won't let me log the target a/f in the commanded a/f or multiplier form... So what i did is i logged the fuel trim cell once again and then i logged the fuel system status bank. The minute i hit WOT it goes to fuel cell 15 and hits Ol-2 on the fuel system status from cl-1, so from my logging it looks like it is going into PE right?. Here is a log that i exported in excel format if anyone wants to take a look : http://67.181.237.183/calfiles/screenshot/450512.csv
http://67.181.237.183/calfiles/screenshot/450522.csv
