VE Tuning w/ a Supercharger
Ok I have searched and looked through every freaken post about tuning a S/C most of them only cover injector scaling and IFR tables and what not.. only a few touch VE tables but don't go into detail.
My questoin is do you tune the VE table for forced induction like a NA engine? I read one post that your not suppose even run the car in SD mode w/ FI unless you have a 2bar MAP. I don't have a 2bar MAP and don't plan on doning the upgrade.
I logged my LTFT and they are all around -10, -12 .. So this was w/ the MAF still plugged in.. I would take those numbers paste special by adding to my VE table leaning it out and reflash the PCM.... Drive it around and still it would be -10, -12..... By the way this is air being pushed through the MAF not pulled in from the compressor side
What am I doning wrong here?? I know I am goin to get the "Unplug your MAF" but i can't really....
Any tips or comments on this one... I think if this thread takes off you should throw it up in the sticky section to help some other guys out..
