Hp 2 Bar Or Ls1edit?
Old Apr 11, 2005 | 11:29 PM
nick y's Avatar
Default Hp 2 Bar Or Ls1edit?
I tired of thinking which way to go
project will be done end of month and need your input. here's what i am working on:
03 c5 vert ptk te44 58ar all forged 8.4 afr 347 l19 studs lpe pump 97 lines msd bap a/4 tci new 5 lock up clutch.
i'd like to be able to adjust boost on the fly so but then i am not sure that hp 2 bar is all working properly. i dont own either and would also like have either as i can monitor, log.
please let me know your thoughts
i like the sd as i can adjust levels and not flash computer as with ls1edit.
low traction, lower boost levels
Old Apr 11, 2005 | 11:37 PM
P Mack's Avatar
I've heard good results from the hptuner multibar setup but i don't know if it does tuning on the fly. Megasquirt handles boost well and adjusts on the fly. You should post this in the forced induction section if you havent' yet.
Old Apr 12, 2005 | 05:56 AM
smokinHawk's Avatar
ls1e = the old.
definatly get HPT
MS if you plan to go all out.
