Screenshot of weird -40+ trims I see sometimes...input appreciated...
Here is the screenshot. My guess is that it is caused by the ported MAF sometimes being unable to accurately judge airflow at low airflows and less air shows up that it actually reads. It does not happen when I run MAFless. It's kind of annoying because even on long trips my LTFT averages are between 1 and -2 across the board, with the slightly higher numbers up in the decel areas, and the lowest low numbers being on the far left. Also notice that the STFT scale is from -50 to 50, no -25 to 25 like the default is. Any thoughts?
Originally Posted by 99whitews6
Why do the O2's platuea at this point? Im sure you know why, its just something I noticed. The fuel trims linearly drop off with the platuea of the O2's. Just fishing here.
Can anybody out there with a ported MAF verify this for me?
Originally Posted by P Mack
It's cause you have a 98
Originally Posted by horist
COT is disabled right?
Does it only happen on acceleration?
I just realized that I never noticed this issue before my AIR delete. Could this be some weird byproduct of the AIR delete? It only seems to happen for the first few minutes of my drive (most drives around town are short anyways).
