IAC position vs effective area
I can't seem to figure out a solid scientific approach to determining fan airflow adder. It's just been trial and error...I've almost got it now though. not sure what these last few posts are inreguards to ws6snake eater, you say at 177 in drive its 12.5? im trying to fix some idle issues and will have to be doing more when i do my cam so sorry for all the questions but this is turning out to be a great thread for help, taught me a lot, thanks guys
just explain the steps you are doing now if you dont mind
112 114 116 118 120
305 310 310 310 310
becomes:
112 114 116 118 120
260 272 289 300 305
since im a 6 speed i shouldnt need to adjust the in gear table right?
1) cam
2) throttle set screw (or :shudder: drilling the TB blade hole bigger)
3) idle speed
The base running airflow controls how much the IAC opens at idle, the cam requires you to crack it open further, and raising your idle required you to crack it open further. This will usually put you beyond the IAC's capability to compensate, so you crack the throttle blade with the set screw. This can be used to put you close, but you will often end up with ECTs at which your car will not idle properly. The way to calibrate that is through the base running airflow table. You can adjust it close with your trims (I usually put mine a hair higher than it needs to be), but it worked out best after I did that and then poly smoothed it. I hope that answers your question without completely hijacking the thread.
do i convert that over to gms/sec and then subtract that number from the table?
whats the steps in this really? so i get the right airflow for that table, i guess the RAF table, and then do the effective area or what?
my numbers are -.20 lb/min or less, is that really anything to worry about or no?
i am now assuming that after this is done you need to work the RAF table which you can look at the changes per ECT and plot that as well to enter the numbers in the talble, i would assume that would be something that could work, im gonna try it out
reason i ask is what if i change my table around, would this be throwing off the numbers or no?
i think i have an excel sheet that will calculate this all out with the dynamic airflow numbers, i just hope they stay consistent enough in SD and dont every a lot with temp like the fuel trims do...
1) scale it (multiply by x percent, up or down, affects high airflow more than los airflow)
2) cell shift (I think I am the only person that does this, affects low airflow more than high airflow, can be mixed with scaling with pretty good results)
3) calculate a new table from scratch (I have not had luck with this, trims are not consistent enough for me at low airflows, some people have claimed good luck with this)
have u tried redhardsupras way??
well i have a few ideas using some curves you would get from logging and im gonna try that out.
