What changes will I need for just headers?
The search function isn't working at the moment, hopefully someone will have an easy answer so I don't get flamed for what's probably answered somewhere in the old threads
I've installed a stock 01 LS1 in my RX7, and the only non-stock component I'm using is long tube headers. I've got HPTuners, so when I am ready to fire it up I can take out VATS and the rear O2's, and change tire size/gearing, etc. I plan on staying stock for awhile, so I don't really want to spend big $ on a full-blown dyno tune yet.
My question is this: with the headers, is there anything I need to change to avoid running rich or lean and causing problems/damage? I'm not worried about the maximum power I can get right now; I actually only used headers so I wouldn't have to do the exhaust twice. Anyone out there that's changed headers only and compensated for it with quick tuning changes?
Most stock ls1's with headers run rich, not lean so that is not a huge concern You could tune it, but no damage should result. My car stock tuning and longtubes has a 12.5 airfuel ratio.
Ryan
If it's going to just run a little bit rich I can deal with that for now. Just wanted to make sure nothing would be harmed. I'll get it tuned on the dyno once I install a cam, heads or both.
As far as fitting in the car, there's actually a good amount of room. Here's a few pics, I can post more if anyone is interested.
FWIW, when I installed headers on my LS1, my wideband read the same AFR as before.
HP Tuners will allow you to get your car dialed in. You will be too lean w/headers.
Yea, it looks like one hell of ride.!
I guess I wasn't clear enough when I said I have one Vette O2 to reach the driver's side - I do have the other O2 for the passenger side, I just didn't need the longer wiring harness of the Vette part for that side. So I'll have the front 2 intact, and the rears will be deleted with HPTuners.
The other guys said I'd be a little rich with just headers - are you referring to it running lean if I only ran one O2? Or are you contradicting what they said? I'd much rather run rich than lean. If you know something I don't please fill me in. Thanks!
