Part Throttle vs. WOT
If I save the values we brought my PE to on the Dyno can I just put them back when I get done with the VE tuning?
Or will I have to re-dynotune?
Thanks!
14.7/(PE value) = ???
This is the AFR that your PCM is commanding at WOT.
Now I'm betting that your AFR on the dyno was tuned out pretty darn close to 13.0 right? But I think you will find it interesting that your commanded AFR probably does not equal your actual AFR. This will be a reason why you want to retune anyway. Just cuz it's doing what you want, doesn't mean it's doing it the right way. If your IFRs are still stock, then you're already in a good place to where you can start on VE tuning. Undoing IFR messes shows you some VEEERRRY interesting things...
Going for a retune anyway. Hope that issue is addressed.
02' GMC 6.0 Procharger
Hmmm... I'll look at this and try it. My tuning session was more of a 'how to use HPTuners' with a very good tuner anyway. I think he wanted me to refine it when we got done. And then it'll only take a couple of pulls to get the WOT AFR back on track when I'm done, right?
Another question... I showed 0 LTFTs on the dyno, could I modify the other tables and not have to change the WOT at all?
