Cannot seem to run without MAF for tuning VE
Dixit
Phil
what is wrong with that first log? it looks to idle ok?
try to copy the high octane table over to the low octane side, that could pose some issues.
so are you actually givig it gas or is it idling on its own in those logs? let me know exactly what its doing. but i think the car runs on low octane when in SD mode so once you start to drive the car itmight act weird with so little timing.
Also the scans I show you there of the car warming up and warmed up, are at idle, with no gas, just sitting there purring. The other scan is it with it sitting at idle without gas being pressed and then me taking off from a light (which you can see in the scan). I dont see anything wrong in the Scans, not sure what you mean there. All these show the car running with the MAF on. I havent scanned it without the MAF on because most of the time it dies before I can get a good 5-30sec scan. And yes I did copy the HighOctane over to the LowOctane table because it does switch over to the LowOctane in SD mode. VE table is ok because we dont have a secondary like yall do.
Phill99vette - The reason why the LTFTs show a high number on that PID is because I had to do the whole 50% 60% 80% thing on the first 3 columns of the VE table. With that dropping, I new the LTFTs would be off a bunch, now if I corrected it according to my scans, then I would have hotstart issues with the cam. So everyone kept telling me to reduce the first three columns, but no one ever answered my questions on wont that cause my LTFTs to be off at idle a bunch? What you think I should do there?
Dixit
But its definetely going to throw my WOT tune off right?
I wish there was a BIN comparison so I can see how much this moron tuner changed and compare it to the stock 2k2 z06 BIN and then just put the stock BIN back in with the changes I made and the necessary ones.
Dixit
yes it will run leaner, but from the looks of your o2s your not really running too lean. if you were lean they wouldnt really oscillate that much, just from what i have seen on my car, may not be the same for yours but on my car they only oscillate like that if the car is running richer. mine looked like that when i had lower numbers in and when i put actual in it wasnt so active, it said i was richer but it was a false richer, so im just wondering if this is whats causing some odd problems to happen
Dixit
I was working on a reply yesterday and got side tracked. I'll send it anyway and see where your at.
Dixit
Phil
http://www.efilive.com/forum/viewtopic.php?t=1169
Idle with correct IFT table and stock VE table
Now the LTFTs are sitting at +25 at Idle, so I definetely got some VE tuning to do. Major VE tuning.
Now heres the other part, disconnected the MAF and started her up and it was barely holding at 400rpm, I mean barely. I managed to get a scan on it before I killed it in fear of it damaging with it idling at 400 like that.
Idle scan without MAF
What you guys think? Im definetely going to have to make changes to the VE table after the drive home with the scan, I mean thats what Ive been doing for the past few months since I cant do it without the MAF connected.
Dixit
If your tune is close enough you don't need an idle relearn.
Phil
I dont think you coming off as a smartass, Im just learning so Im open to all suggestions. I thought adjusting the VE table according to scans after you reset the fuel trims and wait about 50miles was the best way to do it.
Dixit
Dixit
The computer doesnt trim in open loop if you are running and open loop tune then you wont see any triminng. In closed loop on the other hand you will see it even if you reset the trims. After the first few miles down the road the computer will start learning again
Have you set the MAF falure freq to 0 to disable your maf? If you are doing right
For a Corvette, Do NOT unplug the MAF sensor to disable it for SD tuning. Set the MAF fail frequency to 0. The MAF sensor also contains the IAT sensor. If you unplug it the PCM won't function correctly in SD mode because of the lack of IAT data.
You will get a code P0103 when you do this. Some turn off the code, but I prefer to leave it on to verify that I am in SD mode and the MAF sensor has 'failed'.
