RPM limit of stock PCM?
I dont know if it could ever be set any higher than 8000 using a GM tech tuner....
but no matter where I try...IF I enter more than 8000 and push teh save button...it just goes back to 8000
so I would have to say that 8000 is the limit.....
do you really want to try to spin the LS1 to 8000????
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
depending on Cam and other Mods...
Stock 6000-6200
"Small" cams 6000-6500
"Big" cams 6000-7200
really I dont think I would take the stock bottom end much past 6800....but people are doing it....
disclaimer: I do not take responsibility for where you chose to set your redline at, anything past the Stock Redline you do at your own risk.
Stock 6000-6200
