BS3 or FAST XFI ?
Old May 14, 2005 | 06:42 PM
oOoLy's Avatar
Default BS3 or FAST XFI ?
I need your advice to chose the best system BS3 or the new FAST XFI for my c5 with Procharge f-1 ?
Thanks
Adnan
Old May 15, 2005 | 03:28 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Any intelligent reply will require more details on your set-up.
Old May 15, 2005 | 11:03 AM
NoGo's Avatar
I prefer the BS3.
Old May 15, 2005 | 10:25 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Does either support the C5 drive-by-wire setup?
Check that first.
Old May 16, 2005 | 07:49 AM
oOoLy's Avatar
I need more details about wire setup ?
I don't have enough info about the PCM ....
and if i use the BS3 or the FAST should i remove the PCM and the wire or not ?
Old May 16, 2005 | 11:31 AM
LS1Tech Co-Founder
C5s are drive-by-wire.
See which system supports that.
Old May 16, 2005 | 12:04 PM
oOoLy's Avatar
What do you mean about the drive-by-wire?
Old May 16, 2005 | 12:12 PM
LS1Tech Co-Founder
The throttle is driven by drive-by-wire, not by a cable that goes directly to the gas pedal.
Just go and contact those two places, and see which one even works for your setup.
Old May 16, 2005 | 01:16 PM
oOoLy's Avatar
Ya my C5 drive-by-wire .
what is the way to change it to cable and is it better to change it to cable or not?
Old May 19, 2005 | 12:55 PM
oOoLy's Avatar
Tttttt
Old May 19, 2005 | 01:01 PM
LS1Tech Co-Founder
Cartek supposedly has converted a car or two, contact them.
You need to be a little more proactive in your research.
Old May 19, 2005 | 03:33 PM
OrangeFRC's Avatar
As far as I know, neither supports drive by wire. I converted my C5 and plan to run the BS3. Its not that hard to convert, I used all F-body parts to do it.
Old May 20, 2005 | 04:40 PM
oOoLy's Avatar
Thank you John and OrangeFRC ....
What is the exactle parts that i need it to convert ?
