O2 mV swing, how much is normal?
Could someone tell me what range is normal for O2 mV output?
I get 15mV to 980mV with occassional railing at the bottom that may last for 2-3 cycles before oscilating again. Is this swing accross the entire range 0-1V normal or good? Is it better to reduce that swing and tighten it up?
The O2 sensors switch rich lean rich lean to try to maintain 14.7:1
I reduced idle proportional fuel settings, but resulting mV were hardly noticable.
Can you send/post me a log/screen shot with good O2 characteristics so I can see what a good one looks like?
On initial startup it won't look like this since you start in open loop... and when you have more throttle (I think 44% or 64% is when PE turns on) it'll command a richer AFR
But when in closed loop commanding 14.7 AFR it should switch pretty fast
I guess mine doesn't really look like a sine wave anymore... my stock O2s would look more like a sine wave, switch high, still high but less mv, less mv, switch low, low low, w/the Denso's the switch rate is really fast
The problem is figuring out which airflow mode is being used.
How does that airflow mode table assign values? Is it based on cyl dyn air in g/min?
I was playing around with idle proportional fuel last night. It didnt effect O2 amplitude at all. It may have slowed down the frequency.
They're plenty fine, as long as they are in oscillation, they are doing a narrowband O2s job..
