Car wont frickin idle!
ok i installed an mti lid..drove it around for a while everything was cool...then i put the cags on to get rid of the dumb skip shift..i unhooked the battery when i did this...then i start it back up and it wont idle for ****! and when im driving it...i come up to stop signs and it drops way below 500rpm and almost dies everytime...wtf is wrong? this is on my 02 ws6
Originally Posted by Okie02
isnt there some kinda idle relearn deal i could try?
This is the procedure for the Vette. Not sure if it is the same for your car.
From the 2001 Service Manual:
Idle Learn Procedure
The learned idle procedure needs to be done if any of the following events occur:
- The powertrain control module (PCM) is disconnected
- The battery is disconnected
- The PCM loses power
- The PCM is reprogrammed
The engine idle is unstable when the learned idle position is lost.
Automatic Transmission
Perform the following procedure in order to return the learned idle to the correct position:
- Turn OFF the ignition.
- Restore the PCM battery feed.
- Turn OFF the A/C controls.
- Set the parking brake, and block the drive wheels.
- Start the engine.
- Ensure that the engine coolant temperature is more than 80°C (176°F).
- Shift the transmission into Drive.
- Allow the engine to idle for 5 minutes.
- Shift the transmission into Park.
- Turn OFF the engine for 30 seconds.
Manual Transmission
- Place the transmission in Neutral.
- Start the engine.
