cold start: how to fix rpm over/undershoot
Old Jun 9, 2005 | 09:51 PM
WS6FirebirdTA00's Avatar
Default cold start: how to fix rpm over/undershoot
i start my car and the rpms go up to ~1350 then way way low to about 400 and then over shoots again to 1100 and then goes to 900 and then back out even at 1000.
i also see that the dynamic airflow fluctuates a lot too with the iac count staying the same. i dont know what i can do here or what i can adjust really. any ideas?
also i cant find out the max iac position, what is the max number of iac counts?
Old Jun 9, 2005 | 09:53 PM
also, can i adjust idle spark,i see it goes down to 1.5* at peak rpm and at about 22* at lowest dip in rpm and once it evens out its only at about 12*, is this normal or no?
Old Jun 9, 2005 | 10:40 PM
wrencher's Avatar
wrencher
Sure sounds like a mechanical issue & not a tuning issue?
Sounds like a vacuum leak to me, if IAC is not reacting.
Old Jun 9, 2005 | 11:19 PM
2xLS1's Avatar
Your adaptive idle spark control - overspeed/underspeed is probably causing the timing instability and may even be agrivating the condition.
Old Jun 10, 2005 | 04:59 AM
there is nothign wrong, this happens for about 10 sec when you start the car cold then its fine. the iac motor is at 310 right now and i dont know if i can set it higher. the tb is ported and epoxy fillled with copper tube so its letting less air in, but i have read of oters with this problem and stock tb. once the car warms up just a little bit its alright.
Old Jun 10, 2005 | 05:00 AM
yeah i was thinking of this, ill give it a shot and see what it does. do you have any ideas on a good starting point? and do you know if there is a way to adjust cold temp timing
Old Jun 10, 2005 | 06:23 AM
99whitews6's Avatar
I have the exact same problem so keep us posted. I have tried messing with the RAF table although I havent had any luck. This problem came about when I plugged the MAF back in after SD tuning(not sure why this happened since it is in open loop at cold start).
This was not a problem on cold start ups when I was still in SD mode. Why would this start after pluggin in the MAF?
Old Jun 10, 2005 | 06:42 AM
Black02SS's Avatar
What are your IAC counts at a warm idle?
Old Jun 10, 2005 | 08:24 AM
hot idle the iac counts are about 30, once the temp is about 160*+ at about 130* the iac counts are right at about 65-55. ive opened the TB blade more but if i go any more then im gonna be left with 0 iac counts on hot idle
Old Jun 10, 2005 | 11:52 AM
sevanseriesta's Avatar
My Iac accounts do not go to 0 ever is there something wrong with my car.....Do you also think that may be the reason why it is not idleing right.
Old Jun 10, 2005 | 04:07 PM
it shoudlnt go to zero at all, min should be about 30
Old Jun 10, 2005 | 05:40 PM
Black02SS's Avatar
Yes, you need them to be around 30-60.
Old Jun 12, 2005 | 07:58 PM
Larry's Avatar
What values would you recommend starting with?
Old Jun 12, 2005 | 09:09 PM
i would like to knw this as well, dotn want to change it too mcuh
Old Jun 12, 2005 | 09:35 PM
2xLS1's Avatar
Zero out the table to see if that is what is causing the problem.
Old Jun 12, 2005 | 09:46 PM
underspeed is already zeroed out, ill zero out the overspeed and check out how that is.
Old Jun 13, 2005 | 05:39 PM
Larry's Avatar
No luck. Probably cycles more.
By Brett Foote | 2026-06-04 05:00:17
