throwing a code...please help
Old Jun 18, 2005 | 02:19 PM
chandlerc5's Avatar
Default throwing a code...please help
scanned it and it was P0113...which is inlet air temp. so naturally i bought a new sensor, cleared the code, and it still came back...why, what am i missing? BTW, car is a 99 c5
Old Jun 18, 2005 | 02:30 PM
405HP_Z06's Avatar
Check out this link: http://www.gearchatter.com/viewtopic10077.php
It should help you troubleshoot this code. Is this the only code you are getting?
Old Jun 18, 2005 | 02:38 PM
chandlerc5's Avatar
that was the only code
Old Jun 18, 2005 | 02:58 PM
405HP_Z06's Avatar
Time to break out the DVOM! You may want to check your original IAT sensor, it's probably okay.
Old Jun 18, 2005 | 03:02 PM
chandlerc5's Avatar
dvom...u lost me there...kinda new to this whole diagnostic thing...sorry, and where would i get one of those
Old Jun 18, 2005 | 03:09 PM
405HP_Z06's Avatar
Digital volt ohm meter. Any electronics store would carry them.
Old Jun 18, 2005 | 04:19 PM
SUPRYZE's Avatar
Do you have a scanner capable of reading Data or is it just a code reader? I would be looking to see what the air temp showed. -40° indicates an open in the circuit and 300° (or thereabouts) indicates a short to ground. You can use the DVOM as mentioned before to check for resistance in the wires and for a short to ground.
Old Jun 18, 2005 | 04:51 PM
chandlerc5's Avatar
very nice...thanks for all the advice...like you said, time to break out the dvom...
surpryze, it was just a code reader...just trying to avoid taking it to the dealer for a troubleshooting session
Old Jun 18, 2005 | 04:52 PM
chandlerc5's Avatar
especially since it affected my shifting, damn this thing shift hard now
Old Jun 18, 2005 | 04:54 PM
405HP_Z06's Avatar
Yep, the PCM uses the IAT sensor for its airmass calculation. When it's gone the PCM goes into reduced power mode.
Old Jun 18, 2005 | 07:36 PM
SUPRYZE's Avatar
I own a Tech2 & HP Tuners. If your near Charlotte, NC maybe I can help you.
If not, then the DVOM will be your best buddy
Old Jun 19, 2005 | 03:12 PM
chandlerc5's Avatar
damn...i am in TX...sounds like a dvom it is
