I dont now How to tune the cam shuft
Hi to all just i have question if any one can help me , i have camaro Z28 2002 model and it A4 transmission ,I chang the cam to :
Advertised Duration: 269 int./273 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.532
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.532 exh. lift
Lobe Separation (degrees): 114
so can any one till me what i have to chang from the ls1 edit because i don't now what to do,,
thank you ,,,,,,,,,,,,,,,,,
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
