logging LTRIM readings - OBD-2 software
Old Jul 12, 2005 | 09:48 AM
robertbartsch's Avatar
Default logging LTRIM readings - OBD-2 software
Can anyone provide detailed instructions on how to log LRTIM data on OBD-2 diagnostic software?
Which paramerers are important?
How is this information logged in OBD-2?
Is it necessary to cut and paste the data to MS Excel to average the data?
Thanks...
Old Jul 12, 2005 | 10:01 AM
Gordy M's Avatar
What does LTRIM mean, is it long term fuel trims or something similar?
Old Jul 12, 2005 | 01:18 PM
405HP_Z06's Avatar
Thanks...
Which scan software are you using? LTRIM and STRIM are both SAE generic PID's, so they should be supported in all scanners. If the scanner your using doesn't have an average feature than you will have to export the data and use Excel.
HTH
Old Jul 12, 2005 | 03:38 PM
SHRTFT1%
LONGFT1%
SHRTFT2%
LONGFT2%
These are the OBD-2 software parameters that were used by a friend to check the air/fuel/timing curves. As I recall, he belived the readings should be slightly negative.
I'm not sure why software companies such as OBD-2, LS1Edit and others do not provide explainations to helpo users understand their products.
Old Jul 14, 2005 | 07:14 AM
405HP_Z06's Avatar
SHRTFT1%
LONGFT1%
SHRTFT2%
LONGFT2%
Those 4 PIDS would get you fuel trim info, but won't help you on timing.
You will also want to log the enhanced FTC, and FTL PID's and not include the datapoints in your average's that have the FTL as 'disabled'.
For timing, you will want the following:
SPARDADV - Generic
KR - enhanced
Old Jul 14, 2005 | 05:43 PM
Fran D's Avatar
SHRTFT1%
LONGFT1%
SHRTFT2%
LONGFT2%
Robert, are you using the OBD-2 software from Alex Peper? If so, I have already constructed some Favorites files that will get you the parameters you need for LTRIM and WOT tuning. You need to have the most recent version of the software and of the enhanced LS1 F-body bin file, which you can download from his site. If so, let me know and I'll email you the files.
Old Jul 14, 2005 | 06:53 PM
405HP_Z06's Avatar
Fran D,
I would be interested in the favorites you have constructed for Car Code OBD-2. I use it occasionally just for kicks.
z06_pwr@mac.com
Old Jul 15, 2005 | 02:06 PM
Yes I am using the Alex Peper version of OBD-2. I downloaded the latest version of this software two weeks ago.
What is an LS1 F-body bin file?
Is it possible to send these files to me; I need instructions on how to use them, however?
robertbartsch@kpmg.com
Thanks..
Old Jul 15, 2005 | 03:17 PM
Fran D's Avatar
Go to his download section and select "GM 5.7L V8 LS1 F body (update 07-18-04)" from the drop-down list on enhanced real time data base streams. If you did the "Complete" install, it's possible that you already have it. Just look for LS1F.BIN with a date stamp of 7/15/04 in your install directory. If it's there, you're OK.
I'll send 'em to your email address. To use them, go to "Favourites" on the menu bar (Alex must be a Brit) and select Open to browse to the appropriate file. Then, you're good to go.
Have fun.
