Major hesitation issues in a 98Z
I have HPTuners and logged some runs with and without the MAF. Fuel trims are relatively at 0 at part and WOT and there is the infamous 3 degrees knock at the higher rpm's. AFR is around 900mv's and spark is around 24-25 degrees. I was expecting to be given a clue when I did some logging but the numbers look good relatively.. This ar seems like it has lost at least 100hp easy..
What should I be logging to see if it is out of whack and what else should I check/change?
Thanks for the help..
Would you be able to hear a bent pushrod and would it seem like the car lost most of its power from that? There is no noticable sound coming from the engine bay.
Any ideas on what else to check??
