ls1edit ????????????
Old Jul 23, 2005 | 05:48 AM
NAVY's Avatar
Default ls1edit ????????????
I was doing read by using a cable for the ls1edit computer then the cable have been disconneted, now every time i start the car it does want to start, what should i do? is there i something any body can tell me that i can do ? me as soon as possible.
many thanks
navy
Old Jul 23, 2005 | 05:59 AM
Predator's Avatar
Try disconnecting the battery for a few minutes.
Old Jul 23, 2005 | 10:09 AM
WicketMike's Avatar
if you where just reading it, it shouldnt give you a problem..
try what predator said, if that doesnt work, upload a new file and then it should work
Old Jul 25, 2005 | 04:21 AM
NAVY's Avatar
thank you my feind , but my car doesnt worknot .
where i faund a naw file ?
navy
Old Jul 25, 2005 | 05:30 AM
Black02SS's Avatar
Does it connect to edit at all? If not, you have joined the club of fried PCM's. That is why I don't trust LS1 Edit. If this is the case, PM wait4me and he will hook you up on a new PCM at little or no charge.
Old Jul 25, 2005 | 06:55 AM
wrexed03's Avatar
Does this actually occur with lsedit read pcm disconnect cable pcm actually is considered fried?? Your kidding.
Old Jul 25, 2005 | 07:13 AM
crainholio's Avatar
I don't see how a read process can harm the PCM unless he somehow spiked the class-2 serial bus. I read a warning on Carputing's website a while back about some AC/DC converters being at risk of this.
I'm now over 30 cycles of reading/writing my PCM with LS1-Edit and no "frying", also work with two shops that use LS1-Edit extensively and have had zero probs with F or Y-bodies. That is why I assume these problems are user error.
Old Jul 25, 2005 | 05:13 PM
SmaknaSS's Avatar
I had the car not want to start after my GF took the Key's out of the ignition while I was doing a read, the car would not start after that then I uploaded a new program into the car and then the car would now start after that, but the very next time I tried to use edit, I was not able would not read or write to the PCM any longer. two PCM's and one F@#!ed up cable useing LS1 edit,and F@#!ed up costomer service,your better off getting another tuning tool like Flashscan or HP tuners, I feel LS1edit just plain S#cks. BTW I love my Flashscan with Black box logging. JMO.
Old Jul 26, 2005 | 02:23 AM
NAVY's Avatar
thank you my freind im very happpppppppppppppppppppppppy my car is connect ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh to day is racing
thank you very very very very very very very very much my freind .
navy
Old Jul 26, 2005 | 02:27 AM
Black02SS's Avatar
How did you end up resolving the problem?
