MAF sensor low frequency
Old Jul 24, 2005 | 05:32 PM
1BAD02WS6's Avatar
Default MAF sensor low frequency
i threw this code last week i have since changed MAFs (both stock) and the code still stands. So other than cleaning the connections (which iv done) what else should i check??? and what would cause this?? this didnt come on until a few weeks after my tune
my mods are lid ported tb MTI X1 cam.
Old Jul 24, 2005 | 07:10 PM
Dixit's Avatar
If you've tuned the VE table, then most likely your MAF calibration is off. That code is normally because its exceeding the P0101 table where it shows how much it can be off before it throws the code.
If your VE table is on point, then use some of the MAF calibration spreadsheets in this forum and re-calibrate your MAF. It will get rid of that code and your LTFTs will be inline with the MAF running.
Dixit
Old Jul 24, 2005 | 11:35 PM
1BAD02WS6's Avatar
Or I could check the engine sensor fuse and see that its blown lol geez im an idiot. I cant believe I bothered the gentelman that tuned my car with an email before i checked the freakin fuse.
Old Jul 25, 2005 | 12:24 AM
2xLS1's Avatar
It was no bother at all. Glad I could help and that it was a simple fix.
Old Jul 25, 2005 | 04:24 AM
NAVY's Avatar
check the wair for maf
