Switching from a 00 to and 01 single VE table program
Old Jul 24, 2005 | 07:42 PM
Phil99vette's Avatar
7 Second Club
Default Switching from a 00 to and 01 single VE table program
What do I need to do to switch from an 00 to 01 operating system? I want to eliminate the dual ve tables.
Phil
Old Jul 24, 2005 | 11:09 PM
Black02SS's Avatar
I would copy all the values that you have "changed" into the 01 file, including the VE table. Check to make sure that in your current tune the Primary and Secondary reflect each other. If so, just copy the Primay to the 01 file and you are set. If you need help on this, I can do the conversion here in a few mins.
Old Jul 25, 2005 | 09:47 AM
7 Second Club
Phil
Can I use any year from 01+ if I have the HP Tuner cable to match?
How do I upload? Write Entire VCM?
Phil
Old Jul 25, 2005 | 10:13 AM
HumpinSS's Avatar
re write entire vcm with the os you want to flash to... You cell phone must be dead i left a message earlier this monring
Old Jul 25, 2005 | 10:25 AM
soundengineer's Avatar
yeah...juast rewrite the entire computer..just make sure you copy all values in every table across before you burn the file...
did it to mine...and it was way easier to do my tune after that...
Old Jul 25, 2005 | 10:37 AM
Black02SS's Avatar
What they said.
Old Jul 25, 2005 | 10:49 AM
7 Second Club
Alright, got a problem. I have 2 HP tuner cables
1 - 99 - 00 vette
1 - 98 - 01 - 02 vette
Its saying that I can't put the 02 program into the 99 because the cable doesn't match the base year.
Phil
Old Jul 25, 2005 | 08:25 PM
Black02SS's Avatar
Well Phil, you have a small problem. You have 99 on a separate cable and it won't allow you to switch OS's. You need to have the year of the car on the cable AND the new year you want to put in. you can't put a 01-02 on the 99 because THAT cable doesn't have 99 on it.
Old Jul 25, 2005 | 09:17 PM
7 Second Club
Can I have the Dealer reflash the PCM to a 02?
Old Jul 25, 2005 | 09:21 PM
Black02SS's Avatar
I dunno about that Phil, you might be able to. Call Larry and see what he say's, I know he has had several dealings with the dealer.
Old Jul 26, 2005 | 11:47 AM
bowtieman81's Avatar
Not to hijack the thread, but if I have a stock 2000 .bin file, and I want to upload a stock 2001 .bin file what is needed? Just chang the primary VE in the 2001 file? Otherwise everything else will work fine?
I thought there were more differences between the 00 and 01 programs. Just wanting to check before I do something I shoudn't.
Old Jul 27, 2005 | 10:52 AM
M_T_0's Avatar
I have a 99 vette and my HPtuners is for a 99 vette as well as 02 vette (2002 is the latest year that used the same PCM after that the memory is doubled to 1mb)
I'm about to convert my pcm to 2002 and I know that the main diff. is the ve table and the injector flow rates as well as the maf table.
so in order to do this I need to take a 2002 bin file change All of the tables to match the values from my car then rewrite the PCM with the 2002 bin.
after this what happens to the vin number on my pcm? will it not match my bcm and other items? this is where I get lost and HPtuners has not been really helpfull they want me to buy the upgraded 1bar setup.
Is there some place where this issue is written up so that I can work it out?
More Than Zero
Old Jul 27, 2005 | 11:12 AM
HumpinSS's Avatar
you will not be able to change your vin number and will be running around with an 02 vin number. That scheme is pretty foolish to me and I was faced with the same issue until i started using Flashscan.
Old Aug 10, 2005 | 12:22 PM
CAT3's Avatar
Restricted User
Ok, another one that might want to change from 2000 to 2002 os. It would be easier to not have the sec. ve table, but are there any other issues to this swap? I have both 2000 (my car) and 2002 on my cable. Cant I alter the VIN with HPTuners once the os is copied over using the change VIN feature, or is it the 02 os wont recognize the 00 VIN? If it is only the VIN, will that effect anything I need to do, or simple have a different number in there?
Thanks,
Charlie
Old Aug 10, 2005 | 12:30 PM
Black02SS's Avatar
Nope, I don't belive you are able to change the vin back to your 00 one. It isn't that the OS won't recognize the VIN, HPT has disabled that feature. It doesn't effect anything except you know you have a 02 vin and os on your 00 car.
Old Aug 10, 2005 | 01:07 PM
RedHardSupra's Avatar
a friend of mine has a 02, and i have a license for 01, can i just flash him with 01 bin and have everything working fine? 01 and 02 supposed to be almost identical, right?
Old Aug 10, 2005 | 01:09 PM
Black02SS's Avatar
No, if you don't have support for a 02, then you can't flash his car. If that was the case, then there wouldn't be a license structure.
Old Aug 11, 2005 | 12:37 AM
CAT3's Avatar
Restricted User
Chad, when I had some major issues using HPT on my buddies 02, I had to grab a stock 02 tune to put in his car, then I had changed the VIN to match his using the feature in HPT. So I am not sure, but I could have swore I changed his VIN, maybe thats disabled on an updated version?
Old Aug 11, 2005 | 12:47 AM
Black02SS's Avatar
You probably did. You changed a 02 bin on a 02 tune. You can change the vin I believe on corresponding years, but not on a mix and match (00 vin on a 02 tune).
Old Aug 11, 2005 | 01:51 AM
CAT3's Avatar
Restricted User
I was wondering that part, thanks for addressing that. Damn it. So, the absolute only issue will be the number in the pcm, nothing else? Cool, no BCM issues right?
