Attention Cartek or anyone using their C6 TM module.
Old 07-26-2005, 10:12 PM
rms-man's Avatar
Default Attention Cartek or anyone using their C6 TM module.
I want to know if the Cartek TM module will completly disable TM on a 6 speed C6 and if it has any timing control built in.
Thanks,
Joshua
Old 07-27-2005, 11:20 AM
rms-man's Avatar
Anyone...Anyone...Bueller?
Old 07-28-2005, 01:28 AM
Redline-Motorsports's Avatar
I have installed several of there TM modules with great results. They do work. I suggest that if you buy one that you also buy there fan control module as well. I few of the wires in the PCM get tapped by both modules and you can kill two birds with one stone!
Old 07-28-2005, 01:27 PM
LS1LT1's Avatar
Thumbs up
Yes it does completely disable TM on 6 speed C6s (and 6 speed GTOs) and it has no effect on timing other than preventing the timing that would've been pulled if TM were still enabled.
Old 07-29-2005, 09:58 AM
rms-man's Avatar
Thank you gentlemen for the accurate info.
Joshua
