Hot restart
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
When I restart after reaching operating temp motor idles real bad for awhile. Have EFILive, how can I tune this out and what is causing it? Thanks
more than likely, you are runing rich. After a restart, the PCM operates in OL for a few minutes (I believe that is so the O2's have time to heat up). There are several way to go at it. I would start with this
If that doesn't do it, you could work on the OL table a bit.
