Where do open loop fuel trims come from?
Also where do the ftc 22 trims come from? After looking carefully at my logs, it seems that it doesn't usually take the trims from the cell right before going wot. I've seen ftc 15 with trims of 0% and when I go into ftc 22 they're magically 0.8%.
Also I've seen weird stuff like cell 20 trims changing after startup. A couple times I've even seen cell 22 trims change gradually. I thought fuel trims weren't supposed to learn in open loop. Can somebody who has actually looked at the code explain what all goes into open loop fuel trims?
Fuel Trim Group 1, Cells 0 - 3
• FTC 0 - 2 slight deceleration, little to no load
• FTC 3 low load, power enrichment
Fuel Trim Group 2, Cells 4 - 7
• FTC 4 low load, part throttle
• FTC 5 low load, part throttle
• FTC 6 moderate load, part throttle
• FTC 7 moderate load, part throttle, power enrichment
Fuel Trim Group 3, Cells 8 - 11
• FTC 8 - 10 moderate load, part throttle
• FTC 11 moderate load, part throttle, power enrichment
Fuel Trim Group 4, Cells 12 - 15
• FTC 12 - 14 higher load, power enrichment
• FTC 15 higher load, power enrichment, wide open throttle (EPA definition @ 100% Load)
Fuel Trim Group 5, Cells 16 - 19
• FTC 16, Automatic transmission in "Park" or "Neutral", hot idle, a/c on
• FTC 17, Automatic transmission in "Park" or "Neutral", hot idle, a/c off
• FTC 18 hot idle, a/c on (Manual or Automatic transmission in "Drive")
• FTC 19 hot idle, a/c off (Manual or Automatic transmission in "Drive")
Fuel Trim Group 6, Cells 20 - 22
• FTC 20 cold idle, a/c on or off
• FTC 21 moderate deceleration / no load
• FTC 22 higher load, power enrichment
