SD tune service vehicle light on??
Old Jul 30, 2005 | 06:44 PM
pwrtrip75's Avatar
Default SD tune service vehicle light on??
the maf is plugged in and running in SD. Why and how do i get the service vehicle light off (not service engine soon light)
Old Jul 30, 2005 | 07:26 PM
TAQuickness's Avatar
what codes are you getting?
Old Jul 31, 2005 | 01:34 AM
pwrtrip75's Avatar
no codes. the service engine light is not on. the "service vehicle" one is. like when you have the cable hooked up to the laptop tuning it, that light comes on. now it wont turn off.
Old Jul 31, 2005 | 02:15 AM
wait4me's Avatar
Both the p0102 code needs to be turned to c: non emmissions. Then also the p0102 mil light enabler needs to be turned off. Then the service vehicle light will go away.
Old Jul 31, 2005 | 10:18 AM
WS6FirebirdTA00's Avatar
so in hp tuners, i can set it to no mil light, thats the right way to do it right? still report error just dont report it in an mil light? right?
Old Jul 31, 2005 | 10:25 AM
Viper's Avatar
https://ls1tech.com/forums/showthrea...ervice+vehicle
The PCM loses connection to other modules in the 20 or so seconds it takes to wite a VCM. On my car, the light is always on.
Old Jul 31, 2005 | 11:39 AM
Scanning the codes would tell him this.
Old Jul 31, 2005 | 11:46 AM
when i scanned my codes the only one i got was p0103. but this hasnt ever happened over the last 5 months the codes have been shut off.
Old Jul 31, 2005 | 12:43 PM
pwrtrip75's Avatar
I scanned, ZERO codes came up. this has stayed on since i changed my MAF fail frequency to zero and plugged the MAF back in.
Old Jul 31, 2005 | 03:19 PM
see if you can find someone in your area with EFILive or a Tech2 to scan the codes for you.
Old Jul 31, 2005 | 07:05 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I covered this in a post not too long ago...if you go to each of the codes for P0101-0103, and turn them to "SES Off" (actually click on the little circle), you will take care of this problem. Make sure you set the other part of the settings to "No MIL Light"...as long as you don't set it to "No Error Reported", it will still set the necessary codes to get into Speed Density mode, but now you won't have any of the annoying lights.
