why does everyone change the MAP PE enable higher with cam?
Old Aug 5, 2005 | 09:41 PM
  #41
WS6FirebirdTA00's Avatar
you can adjust the map entry and exit settings for dfco, i set my entry to 32 and exit to 40. on decel, the car tends to see a higher map, so on a good decel look what your map is and set the entry 5 above that and exit 8 above the entry. thats just my recomendations though, you can do it how you want to
