trunk mount battery probalems
Old Jul 31, 2005 | 05:04 PM
terr1bleone's Avatar
Default trunk mount battery probalems
im having trouble with my trunk mounted battery, first it wasnt getting enough power to crank the motor (like the cable was disipating the energy), and now since i got a 0/1 cable it seems to be working, but the same thing is happening since i cant find a good ground. any ideas, btw its a 1981 camaro with a 355 sbc and a big dawg power disconnect switch. should i run another length of 0/1 cable back up front to the orignal engine ground on the head?
Old Jul 31, 2005 | 08:18 PM
jimmyblue's Avatar
Moderator
I would definitely not be trying to use the chassis
sheet metal as the ground return for cranking. You
want fat copper from battery - to block ground bolt
and from battery + to starter solenoid.
Old Aug 1, 2005 | 01:36 AM
figured i would have to do that, thanks
