HPT question about Desired IAC steps vs. Desired idle effective Area
7 Second Club
Originally Posted by P Mack
NicD, with a cam it's pretty much a given that the throttlebody will be drilled out or cracked with the set screw, which makes this table a big help for cammed cars.
7 Second Club
It's one of about ten steps that should be done, it's not like the one table that will solve all your problems.
7 Second Club
NicD, i'm not trying to argue with you. It may be that your table doesn't need to be changed, or its off as much as your idle air tables in the opposite direction so it still doesn't need changed.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#33
7 Second Club
Just curious, do you adjust the idle airflow tables to get the idle trims to zero, or to match the dynamic airflow? I'm not giving you ****, i'm just curious about your method.
#34
pro mouse, you can shift cells but IMHO, i wouldnt evne do that any more. i started out shifting and what not and ended up redoing the whole table. the results of a new table are so much better. the desired idle airflow and actual (dynamic) airflow match perfectly. these lines should overlap, through all iac positions.
http://www.allmod.net/hpt/idletune.doc if you scroll down on there you can see how off the airflows were, the car did idle and would not stall but it wasnt perfect. then i got the lines to overlap and i cant begin to explain how much better that helped not only idle but the recovery of idle when reving or stopping.
also, where your table is all zeroed out is the area of all the small openings and cracks in the TB/blade and any airflow that may flow over a fully closed iac valve. the computer goes through all the calculations and determines the area needed to flow the desired air, then it looks up the iac step to open up to allow that amount of air into the car by the mm^2 numbers in the table. if your desired airflow is lower than actual that means the iac step size is too large in that cell and is opening too far letting in too much air. and on the other hand if actual is lower than desired, the iac is not open enough so in the corresponding cell (for the iac step) you would need to increase the iac step number, and do this for the whole range from cold start
#35
Originally Posted by WS6FirebirdTA00
you want to get the idle trims to zero. AFAIK, that is what tells if the dynamic airflow is too high or too low.
#36
once you get dynamic and desired to match it will throw off your idle trims again. ive seen a huge difference in shifting the lines sometimes for overlap, depending how far off you are yuo can chnage desired a few g/sec, and if the trims were right, they would be off by at least that, which would make idle bad again. but you are right if they dont overlap you can mess with the idle trims and get the idle pretty good, but may still have some issues you wont if you just get it done right, takes a little longer but not much more. i read your first statement wrong, and i dont know if i even answered right this time haha
#38
if you need any help email me the log file and tune, budchevy358@yahoo.com
log:
dynamic airflow
LTIT
STIT
iac position
spark advance
rpm
intake air temp
coolant temp
i could get you started in the right direction and point out somet hings for you. ive done 80 cam tunes on my car, just about every day since the end of may, cold start. so ive got a bunch of little things here and there that can help the idle out so much more
log:
dynamic airflow
LTIT
STIT
iac position
spark advance
rpm
intake air temp
coolant temp
