New Version of EFILive released
# Valet Mode Speed and RPM limiters.
# Dual Spark maps retained when MAF sensor has been removed. Provides custom control over high/low octane transition.
# Fuel mixtures can be based entirely on MAP vs RPM with any AFR commanded at any MAP/RPM point.
# Timing reduction table when in boost.
# Uses standard {SAE.MAP} PID in boost, works with any generic scan tool.
# Supports up to 285kPa of boost, that's nearly 3 bar.
For a full list of features and new additions check out
http://www.efilive.com/downloads/v730_updates.html
or visit the forums at www.efilive.com/forum
Anyone download the upgrade yet?
Until the documentation is finished it wont be a public release. In the next week or so it will change status and be cut to cd for distribution. It was made available to us as a courtesy
LS2 Support won't be out until the end of the year from what I hear. They are working now to get the 98' guys up and runing.
The newest update is very nice.
The scanner can even have multiple tables now if you drag them down from the tool bar.Also the Free custom operating systems are AWSOME>>
Ill be upping my boost to 25lbs now on the 408, with the newest version of efilives os, i can use a stock timing table and pull boost from the timing adder table. And then just adjust fuel with one table and put in the exact fuel ratio i want to run, and it is exact..
The trade in deal sounds like a pretty sweet deal
200 bucks trade in for something is pretty cool.. I have A couple cables in stock.
and what is that one thing about fuel mixtures? is that a pe tables based on map? not quite clear on that, or maybe its just too late
I deleted a few comments and reopened this thread since several folks asked.
I want all members that use this forum to be careful when making comparisons between different tuner providers. Comments that we perceive as being argumentative or bashing will be deleted, or we will just lock the thread. There is tension between some of these companies and that's the way we are going to handle it.
John
Bill
John
As an administrator of this forum, we users look to you folks to be fair and unbiased toward all. I trust that in general, all users and sponsors want even-handed treatment for everyone else and they expect to be treated with fairness in return.
Sincerely,
Steve Bryant
