Iac, Experienced Tuners Please
Old Aug 15, 2005 | 04:37 PM
BBADWS6's Avatar
Default Iac, Experienced Tuners Please
Ok guys, I put a larger cam in my car and it now idles much higher. I have corrected the IAC tables to bring the sitting idle down correctly.
When im cruising it hangs up at 2000 for a good while before it comes down, both clutch in and clutch out. When i come to a stop it idles down.
What chart do i tweak to fix this problem? Thanks for your time and imput,
Chris
Old Aug 15, 2005 | 04:47 PM
2xLS1's Avatar
Throttle cracker - Airflow vs RPM vs MPH
Old Aug 15, 2005 | 04:53 PM
TAQuickness's Avatar
might want to look at your iac effective area table as well
Old Aug 15, 2005 | 05:15 PM
WS6FirebirdTA00's Avatar
its all in the idle airflow. i havent messed wiht the throttle cracker or follower and fixed my problems. i did adjsut them for better response at 0 mph. adjust effective area and raf tables, do all logging from cold start
Old Aug 15, 2005 | 06:32 PM
BBADWS6's Avatar
Im still a little bit confulsed about what all of the tables in the IAC do, and what they affect. I have done some searches and it does not seem like too many people are changing theese tables.
Old Aug 15, 2005 | 06:35 PM
ha, search again if there is a table i have changed it
search: getting your car to idle 101
if you dont understand that post back up here with your question and ill be more than happy to answer
here save you a few seconds:
https://ls1tech.com/forums/showthrea...ar+to+idle+101
Old Aug 15, 2005 | 06:41 PM
BBADWS6's Avatar
thanks a lot man, i will be back shortly........
Old Aug 15, 2005 | 06:43 PM
im gonna try and work on it more tonight, since then i have found out even more info
