Reprogramming from LS1Edit
Old Aug 18, 2005 | 10:40 AM
LuvMyZ's Avatar
Question Reprogramming from LS1Edit
Can you use a handheld to reprogram from LS1Edit? I have a '98 Z28 that was programmed using LS1Edit last year. My car needs to be re-tuned, but I don't know where to start. I was thinking of buying a HPTuners or Vinci prgrammer.
I will really appreciate any advice!
Jim
Old Aug 18, 2005 | 12:03 PM
slow's Avatar
your options are edit, and hptuners for the 1998 cars right now.
Vinci's tuner is not available for the 98 cars yet. To be honest I do not know how they program, if they write a full file, based off a full file on the device it could overwrite the tune. however, if it is programmed based on how I would expect, it only writes the changes, which could cause a problem with writing over an edited tune.
Ryan
Old Aug 18, 2005 | 12:07 PM
LuvMyZ's Avatar
That's kinda what I was thinking too. I may need to find someone who can re-tune w/LS1Edit.
Old Aug 18, 2005 | 12:09 PM
slow's Avatar
you can reprogram with hptuners or edit, on a edited file. Or have you pcm flashed back to stock, and use any of the handhelds.
Ryan
Old Aug 18, 2005 | 01:14 PM
ThaLS1KidII's Avatar
I asked this exact same question to Keith at HPT, and he said that the HPT will be able to read, edit and reflash a VCM that has already been tuned using Edit.
Old Aug 18, 2005 | 02:20 PM
TAQuickness's Avatar
When EFILive gets the 98 support going, you will be able to do the same. At the moment though, your only choices would be LS1Edit, HPT, or a Tech2.
Old Aug 18, 2005 | 08:02 PM
LuvMyZ's Avatar
I really do thank you all for the responses and help.
Jim
