oil on spark plug threads
Old Aug 18, 2005 | 11:25 AM
shaZZam's Avatar
Default oil on spark plug threads
Planned on dynoing the car today, replaced stock plugs with NGK's and found oil on the threads of plug #4. The resistor was clean and looked the same as all other plugs, car has no issues, no smoke, etc. Any clues? I am a little wary of putting the car on the dyno until I get some feedback. Thanks.
'01 WS6, Lid only, 29K miles
Old Aug 18, 2005 | 11:45 AM
robertbartsch's Avatar
did the oil come from an external source? clean it off, replace it and run the car around then pull it out again....
If you have a compression testor use it on #6 and compare the results to a few other holes..
I use a special thread lube on most threads that contact aluminum - including plugs
Old Aug 18, 2005 | 12:36 PM
Old Aug 18, 2005 | 01:50 PM
WAHUSKER's Avatar
Any oil that leaks seems to find it's way to the plugs. Kinda like socks disappearing in the dryer. Mine have stuff on them from time to time. Unless a compr check or smoke says you have a problem, I wouldn't worry about it.
Old Aug 18, 2005 | 02:12 PM
TAQuickness's Avatar
I had a very very very slight leak on one of my valve covers - all the plugs on that bank had oil on the threads. Had a little smoke too, but the catch can fixed that.
Old Aug 18, 2005 | 06:51 PM
shaZZam's Avatar
Thanks for the insight, my local mechaninc gave me the okay to dyno, best pull was 296.4 HP and 306.4TQ. And now the adventure begins.....
