Tune
Old Aug 21, 2005 | 06:37 PM
brokez's Avatar
Default Tune
Had my car tuned by a local shop but the car still bucks, and hunts for idle. Is it supposed to still do that even after the tune? The cam is a custom grind but is almost exactly the same as the magic stick. Can the tune be better or do I need gears?
Old Aug 21, 2005 | 07:09 PM
TAQuickness's Avatar
Your tune can be A LOT better.
Start here:
https://ls1tech.com/forums/pcm-diagnostics-tuning/368718-read-me-best-ls1-tuning-software-best-scanner-best-handheld.html
Once you get your tuning software, you will want to get a Wideband O2 sensor.
Old Aug 21, 2005 | 07:19 PM
brokez's Avatar
They used hp tuners to tune it so should I take it back and get a retune?
Old Aug 21, 2005 | 07:37 PM
IMO, it would be better for you to get your own software so you can get your tune the way you like/want it.
WOT is easy to tune - your tuner all ready did that. Overall drivability is a whole different story. Once you get your part throttle tuning worked out, you can go back for a new WOT tune on the dyno. BTW - it's much cheaper to rent a dyno for you to tune than to pay someone else to do it.
