finally got my ve and maf tables decent but...
after modding my ve table my trims were great, i redid the maf table with the availible spreadsheets, after reconnecting the maf my trims went negative pretty hard especially in the lower cells, should i mod the ve table to bring the trims in line or should i change the maf table so it dont effect the trims as much, or did i just do a bad job altogether and this is the result?
I know ive been posting soo many questions lately, and im sorry if this is bothering anyone, but for any ls1 questions this is the place i turn to.
Greg
Greg
if you can unplug the MAF and the trims line back out (might want to reset them then log) then I would say your problem is in the MAF calibration.
Have you tried using the spread sheet available in the stickies?
yeah the spredsheet is what i used to come up with my numbers for the maf, iim going to have to see if removing the maf again corrects the trims, if so i need to adjust the maf table and not the ve table correct?
yes, the problem is maf tuning if the trims line up once its unplugged again.
I disagree with the way most of those maf spreadsheets work. Others disagree but I generally use LTFT vs MAF once its ve tuned to come up with my new maf table. It works out great. My trims as well as customers are between -4 and 0.
I had the exact same problems Ive outlined how I tuned my maf in this link its straight forward and has worked well for me.
http://www.performancetrucks.net/for...d.php?t=346549
good and bad responses are welcome
