need help with tuning plz...
'01 LS1 swap, stock motor and sensors/accessories, stock 4l60e...
Im getting a p0121 code which does not go away with a new sensor. when I punch it at ~40mph it does not downshift, it stays at cruising speed and quickly upshifts to OD and tries to stumble as the rpm's get lower and lower. punch it anywhere else and it runs strong like the LS1 should... I tried changing out a new tps, and I tried changing the min/max to 75/85 with no luck... plz help!!! thanks in advance...
at ~40 mph punch it just kind of bogs down and lays over, and tps shows 100% while its just kind of bogging. it does it every once in a while from a stop as well. any other area in mph/rpm it will drop gears and haul a$$ - has anybody even heard of this? any ideas at all?
