Advancing timing Edit
Old Aug 29, 2005 | 09:42 AM
robertbartsch's Avatar
Default Advancing timing Edit
For the mods in my signiture, I used Edit to advance my ignition timing. I raised it by multiplying the table by 105%. (I also cut the fuel IFR by 10%)
I only raised the ignition timing table numbers for RPM above 2800. Should I consider:
1. adding addtional timing?
2. Addinting any timing to the lower RPMs below 2800?
The car runs strong with this tune.... someday I will learn more about Ltrim monitoring.... I downloaded a Beta LS1Edit program that logs this data but have not learned how to use it yet.
Old Aug 30, 2005 | 06:36 AM
Brent@LPE's Avatar
When I get to work I can send you a spark calculator,but you will have to log MAF to use it it is pretty simple and will show you exactly what cell you in
Old Aug 30, 2005 | 08:11 AM
RedHardSupra's Avatar
spark calculator? what does that do? can i get that too?
Old Aug 30, 2005 | 08:31 AM
Brent@LPE's Avatar
it is just a excel file thatdoes the math for you i will send
Old Aug 30, 2005 | 08:38 AM
Brent@LPE's Avatar
can not upload a xls. file here e-mail me @ work and I will send brent@exoticperformanceplus.com
