Setting AFR for the street versus the dyno?
Thanks!
12.5 for NA, results near 13.1 on street
FI is boost level vs engine component dependent, but the STS I am working on:
11:1 street should be 10.5:1 on dyno, new to FI so dont beat me up too bad.
But basically my work with Dynojet nonloading is about .6 leaner on the street.
changing the commanded air fuel, through the PE table, or calibrating the transfer function of the maf to match the commanded air fuel ratio?
Ryan
Ryan
But if you are not getting what you are commanding, something in the control system is being lied to to get the desired results. This will increase the chances of the air fuel ratio changing on the street vs the dyno.
Ryan
I can't comment on what it reads on the dyno as I dont' use a dyno to tune. I normally shoot for around 12.5-13.0 on the street depending on the car and tune needed.
