TC lockup timing.
Old Sep 7, 2005 | 06:46 AM
Tonner's Avatar
Default TC lockup timing.
is it possible to change how quickly the converter locks up to vary the amount of slip during lock up, if so I will be back with another question,'
Cheers & thanks Tonner
Old Sep 7, 2005 | 09:17 AM
jimmyblue's Avatar
Moderator
You can set the TCC offset table to 99% and it will
have full pressure immediately whenever locked. The
catch is, it's only 99% of the commanded line pressure
so you may not eliminate the slip entirely.
Old Sep 7, 2005 | 02:49 PM
Tonner's Avatar
Thanks Jimmy ,but the problem is its now that I use a vac modulator I have no force motor so can this still be adjusted as it is getting too much pressure I am told,, cos it locks up too tight & too quickly destroying the TC clutch when locking up (3600 Hi Stall)
