HP A4 tune
mods are
3000 stall
3.73 rear
220/224/568/568/114
p1sc about 10 psi
42 lb injectors
lt ory magna flow cat back
see stickies ... they're there for a reason
or do you mean you want a bin that's setup for your mods? if so... i reccomend tuning the car yourself.... trans tuning is a personal thing.... example... I have mine setup so that it won't downshift into 2nd if I'm above 50mph and won't hit 4th till 60mph and won't lock the converter up if it's in anything other than 4th gear... not the best for fuel economy ... but it works great for how I drive it....
unless you're looking for a stock A4 tune to reflash your PCM with (because of a swap) ... you have the software... you have the hardware... so tune the trans to your likings
if you don't understand the various trans tables then post up and people will help converter and 3.42s; motor-wise you're on your own
but the trans tables ought to do it for you. Might be
better to start with an A4 bin and copy engine tables
than vice versa. Especially if the engine stuff is going
to be heavily messed with again anyway.
