Pics of the MS mounted..how do i splice TPS + TAC?
Hey everyone here's a couple shots of my megasquirt that i put together last week loosely mounted in the car. I cut a hole right next to the throttle cable and will mount the MS computer right next to the steering column underneath the dash.The relay box will be right above the stock relay boxes and I plan to make short wire runs for the ground, + 12v, and ignition input on the MS relay box. Which wires at the PCM are for RPM and TPS? I need to splice into them for the MS to work. Also, there are a couple of relays for the ignition how should i hook up the relay board so that when i turn the key to run + start the MS is powered up? Any help will be appreciated.
Greg
Greg
