P0748 pressure control solenoid ?
Does anyone know where the pressure control solenoid is on the ls1 small block. ? I am getting this code, but have no idea where to look at for correcting it. ?
The P0748 is for the pressure control solenoid valve in the a4 transmission. It can be set by open or shorted pcsv.
The P1626 indicates loss of Fuel Enable signal from the BCM to the PCM. The BCM processes the Passkey/Vats info. to create this Fuel Enable signal. When this code is set there will be no fuel delivery-resulting in stall.
The computer I am running is supposed to have the VATS cleared out of it. So i am guessing that it is safe to say that that is not done with the p1626 code flashing ? ?
