Help Blinking SES and Misfire.....
Old Sep 14, 2005 | 04:10 PM
1320_Racing's Avatar
Exclamation Help Blinking SES and Misfire.....
A Friend of Mine asked for my help and I thought that I would turn over to yall
He took his car to AutoZone for a free Diagnostic after his SES started blinking. He was told that he had a misfire on cylinder number 5. So we start off by replacing the Spark Plugs with NGKs tr55s and new wires. So we start it up and the same thing is going on, we go back to AutoZone and still have that misfire. What else can we look for? Also he says that the SES light started flashing right after he raced. Any Ideas?
Old Sep 14, 2005 | 04:41 PM
01black's Avatar
i am having the SAME ******* problem!! I have been trying to figure it out for months now!!! I have changed to TR6 plugs, changed my push rods, changed plug wires twice....'m going to try new coil packs next....I'll keep ya informed...my car stutters at like 5k rpm's or so....when does his happen?
Old Sep 15, 2005 | 02:11 PM
TTT..... Come on Someone has to have an idea. I was just told that the car is now smoking really bad.
Old Sep 15, 2005 | 02:45 PM
Bad Blu Formula's Avatar
New coil packs or a possible broken pushrod.
Old Sep 15, 2005 | 02:54 PM
black01_WS6's Avatar
have you tried cleaning the maf sensor. sometimes when it clogs up it sets off all different codes. I had a misfire on #6, and only after new wires and plugs did we figure it out. you can clean it with contact cleaner the fast drying type, or rubbing alchol. you can atleast try it, its free and might save you some time.
opps didn't see that you were blowing smoke.
dogger's Avatar
o1black I am pretty sure you need to have your fuel filter replaced and replace your injector's. I've fixed this on a couple car now.
1320 racing your's could be the same problem but I won't bet the bank on it. alway's worth a shoot though.
Old Sep 15, 2005 | 03:08 PM
2LATEULOSE2's Avatar
I had the same thing happen to me I changed the coil pack and it fixed the prob.
Old Sep 15, 2005 | 10:08 PM
Was your car smoking though?
Old Sep 16, 2005 | 12:02 PM
hourang's Avatar
swap the coil pack to a different cylinder, see if code moves. can also swap injectors. also check the springs/rocker/pushrod on that cyclinder.
