Where are the IAC counts found in the HPTuners Scanner?
As the title states, I cannot find the IAC counts in any of the displays in the scanning tool.
Where are they at?
Thanks.
Where are they at?
Thanks.
Simple my friend... open up the table display (be sure to not be logging), and right-click on one of the blank PID tables and click on "insert". You'll see a whole plethora of data to moniter. Before you add the IAC counts though you will have to remove 1 or 2 PIDs (ie. vehicle speed and maybe you don't care about fuel trim cell). Because you only have 24 data bytes to play with and the default setting uses all 24. Did that help any?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Third Gear
Simple my friend... open up the table display (be sure to not be logging), and right-click on one of the blank PID tables and click on "insert". You'll see a whole plethora of data to moniter. Before you add the IAC counts though you will have to remove 1 or 2 PIDs (ie. vehicle speed and maybe you don't care about fuel trim cell). Because you only have 24 data bytes to play with and the default setting uses all 24. Did that help any? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Where were you yesterday??
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Thanks for the info, I found it in the software here at work and I'll give it a run when I get home tonight.
Is IAC counts the same as Engine-->Idle-->IAC Position?
