multiple misfires
Old Sep 17, 2005 | 08:15 AM
EXILE's Avatar
Default po300
went to the track lastnight ran 3 times everyone had a multiple misfire code car would pull hard and my time got faster on every run but the 1000 ft time stayed about the same seems like i was getting the misfires shifting to 3rd i assume its a bad plug wire checked the plugs
Old Sep 17, 2005 | 12:39 PM
EXILE's Avatar
Default multiple misfires
ran 3 times at the track every run had the multiple misfires reset the pcm think i have a broke rocker arm fixing to go pull the valve cover would that cause the p0300 misfire?
Old Sep 18, 2005 | 12:19 PM
EXILE's Avatar
anyone!?! i pulled the valve covers everything is good there plugs are good so now im think coil packs and or the plug wires
Old Feb 20, 2006 | 06:29 PM
salem's Avatar
clean your throtell swich
Old Feb 20, 2006 | 06:33 PM
Syxx613's Avatar
check ur o2's.
