A Little Help!
Old Sep 18, 2005 | 07:39 PM
TransLS1's Avatar
Question A Little Help!
I went to AutoZone today to check what my computer was saying, about anything . And the guy pluged the scanner in the data port and nothing came on , so I popped the hood and checked the fuse and it was ok (i think it was the right one anyway?) so im at a loss for words right now. Does anyone have any advice on the matter? Thanks in advance
Old Sep 18, 2005 | 07:41 PM
wait4me's Avatar
The correct fuse would be the cigarette lighter fuse.
Old Sep 18, 2005 | 07:59 PM
2001NBMZ28's Avatar
Check the "CIG/ACCY" fuse inside the car, in the main fuse block.
Old Sep 19, 2005 | 03:29 PM
TransLS1's Avatar
it looks fine. what else do you guys think? i looked at the wiers behind the port and they look good. i dont know.---Andrew
Old Sep 19, 2005 | 05:07 PM
2001NBMZ28's Avatar
If the fuse is good...and the cigarette lighter is working...you can probe the DLC pins with a voltmeter to check for power - www.obdii.com/connector.html explains them. Dunno what else it could be, maybe a bad scanner/operator error at that AZ? Got another AZ you can go to?
Old Sep 19, 2005 | 05:26 PM
2001NBMZ28's Avatar
Went outside and probed mine - 4 & 16, 5 & 16 have power, even with the ignition off. When I remove the fuse it goes dead.
